StormchargedVR6 0 Posted November 26, 2009 Can't find anyone does the hose size for TB on VR6 , its got to be a reducer from 3.25 to 2.5'' Got one few years ago in blue, but need black. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 26, 2009 Shaun,the diameter of the throttle body is 80mm not taking in to account the 83mm with the lip so you will find a 3" hose will push onto it as i have done. So 80mm to 63mm is what will work for you.....click me other than that its custom made. Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted November 26, 2009 Shaun,the diameter of the throttle body is 80mm not taking in to account the 83mm with the lip so you will find a 3" hose will push onto it as i have done. So 80mm to 63mm is what will work for you.....click me other than that its custom made. Cheers James , where did you get yours Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted November 26, 2009 http://www.viperperformance.co.uk/index.php http://www.sfsperformance.co.uk/ they are the two i mostly use,if they dont have the size listed give them an e-mail as they do all sorts. Cheers Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted November 26, 2009 http://www.viperperformance.co.uk/index.php http://www.sfsperformance.co.uk/ they are the two i mostly use,if they dont have the size listed give them an e-mail as they do all sorts. Cheers Cheers James :) Quote Share this post Link to post Share on other sites
