Topaz2008 0 Posted December 3, 2009 Last week I tried to replace one of my front lower suspension arms. Unfortunately the securing bolt that runs from front to back snapped in the sub frame :epicfail:. This had been replaced before by a previous owner as I have a receipt for it but traces of loctite were found around the bolt :cuckoo: Various attempts at drilling the bolt out failed leaving me with no choice but to replace the front sub frame :censored: :censored: . I have been offered a sub frame from a MK2 Golf 16v :D but when I check on ETKA the part numbers are slightly different :confused4: :- Golf 16V = 535 199 315 AD Corrado G60 = 535 199 315 C Does anyone here know the Golf sub frame will fit? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 4, 2009 Nope - it's not got the extra mounting points - the only MK2 Gold one you can use is off a G60 Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 4, 2009 someone mentioned the other day that they'd used a (non GTI or VR) mk3 golf subframe, although I think one bolt hole needed drilling, should be a very cheap alternative. Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted December 4, 2009 Supercharged said: Nope - it's not got the extra mounting points - the only MK2 Gold one you can use is off a G60 What extra mounting points are these? DO you have any more info? Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 4, 2009 the g60 one have like a little leg extending back from the arb mount area Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted December 5, 2009 steveo29 said: the g60 one have like a little leg extending back from the arb mount area Thats a very nice looking subframe :D Is that one in the pic Corrado or Golf? I was not sure if the red circle showed the bracket thingy or where it should be. My car is in store at the moment so its not that easy to compare. Sorry to be a retard but will it fit without the thingy?? :D :D Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted December 5, 2009 I think I see what you mean in this picture from Vortex :shock: Quote Share this post Link to post Share on other sites
steveo29 0 Posted December 5, 2009 yeah your vortex pic shows the legs im on about... Quote Share this post Link to post Share on other sites
mikkijayne 0 Posted December 12, 2009 You can use the mk3 one with a little modification. The legs on the back are longer on the mk3, so you need to cut them down and drill a new hole to match where it is on the Corrado legs, then it will bolt up to the body. The rear engine mounting is different on the mk3 subframe though, so you will also need the engine mount and the bracket from the back of the block from a 4-cylinder (1.8-2.0) engine, which will fit fine on the back of your G60. I did this swap on my 16V because the original subframe had cracked and all I could find was a mk3 one. It worked just fine :) I wouldn't be inclined to use a mk2 subframe without the legs - they were obviously added to stiffen the front end up, and it might spoil it if you didn't have them. Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted December 18, 2009 I am on the road again :D :D :D New subframe and arms + bushes etc all fitted and I have my car back...... And today it :censored: snows :( A G60 has enough problems putting power down on a damp road so the snow is going to be a nightmare. Quote Share this post Link to post Share on other sites
turlock 0 Posted December 30, 2009 Congrats!! What frame did you use? Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted December 30, 2009 Managed to get a G60 frame off the Forum, so it was a straight swap :D :D Quote Share this post Link to post Share on other sites
shaung60 0 Posted December 30, 2009 Topaz2008 said: Managed to get a G60 frame off the Forum, so it was a straight swap :D :D :wave: Quote Share this post Link to post Share on other sites
Topaz2008 0 Posted December 31, 2009 shaung60 said: Topaz2008 said: Managed to get a G60 frame off the Forum, so it was a straight swap :D :D :wave: Thanks Shaun :clap: :clap: :clap: :clap: Quote Share this post Link to post Share on other sites
