brunt_star
312 brakes
you use your excisting hubs all you need to do to fit the 312's is ensure you use a 6 mm spacer when you fit the carrier to the hub
you can use washers or D&G do a rather nice fitting set for em
Its all in the caliper bracket really, I'm fairly sure Ibiza/Leon brackets fit straight on. Otherwise its a custom bracket which means you can have almost any disk/caliper setup.
