Josh Waddi 0 Posted December 18, 2009 Post re-edited Details added to the bottom. Will MK4 rear calipers fit straight onto my current standard setup. 1991 1.8 16V. If not what will be needed to make the adaption, i also have the caliper carriers. Thanks Quote Share this post Link to post Share on other sites
volksworld13 0 Posted December 18, 2009 the screw holding the handle in is a left hand thread try turning the screwdriver the other way and it will come out, if you look closely it has an arrown marked the the screw, if its not too rusty. :D Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted December 18, 2009 U lenend, my eye sight is shocking so clearly i just missed this. The screw was fine before i destroyed the head as it was replaced when the repair kit was fitted. Hopefully be able to fix this now. Thankyou Quote Share this post Link to post Share on other sites
dragon green 5 Posted December 18, 2009 On one of my handles, the screw wouldnt come out ! in the end i had to angle grind it off, very carefully ! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted December 18, 2009 On one of my handles, the screw wouldnt come out ! in the end i had to angle grind it off, very carefully ! Probably the drivers side which is a reverse thread - note the arrow on the screw! Quote Share this post Link to post Share on other sites
dragon green 5 Posted December 18, 2009 On one of my handles, the screw wouldnt come out ! in the end i had to angle grind it off, very carefully ! Probably the drivers side which is a reverse thread - note the arrow on the screw! Until i found this site i had 5 drivers handles and two passenger handles, IIRC it was number two that wouldnt come out ,as i have replaced all handles myself, i know they where all right hand thread ! Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted December 18, 2009 Most definatly the drivers side being reverse thread, ive had the passenger one out no problem. Thanks again. Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted December 19, 2009 bump, thread edited, Quote Share this post Link to post Share on other sites
dragon green 5 Posted December 19, 2009 found an old broken door handle,(drivers) the part that usually breaks is the small part laying by the handle This is the part Daves16v sells in stainless steel, hope this gives you an idea what you are looking for Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted December 20, 2009 Thanks for the help guys, gonna need 2 new handles how fun. Thanks for the guy who rang me, managed to get rear caliper carriers from a MK4 golf. was wondering if they will go straight on my current disks or will i need different ones? the pads are fine and fit. just dont wanna take my brakes apart and not be able to re-buld them back up. Need a swift reply on this people as i cant get to wrk tomorrow, no work no dollar!! Thanks again Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted December 20, 2009 You'll need different hoses to fit the calipers. Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted December 21, 2009 Right, so it would be just cheaper and easier to buy a new caliper? Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted December 21, 2009 I guess so, although if you've already got the calipers and can get the hoses quick enough and have the time to fit them all they'd be better by all accounts. Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted December 21, 2009 Hi, im having a nightmare with this now, new caliper bought from GFS, fitted, just tested the brakes and all the fluid has pumped out!!!! any ideas? not used to this hands on approach. everything went on the way it came off and the hose was on as tight as possible. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted December 21, 2009 Did you check the bleed screw was closed before you tried to bleed the caliper? Quote Share this post Link to post Share on other sites
Josh Waddi 0 Posted December 22, 2009 Hi the bleed screw was on very tight, ive found what it was, THE NEW CALIPER!!!! Just to let you all know the joys of buying parts from GFS. Phoned up to check they had the part in, yes said the sales rep and advised it was £79.99. I questioned the amount he quoted as i had looked on thier website and it was £49.99. He came back and said the part number had changed and i was correct. So i go down (12 miles away in this snow) and the guy says theres a £30 sur-charge on the part with exchange for my old one. I basically told him where to shove-it. Got the caliper for £49.00 and then fitted it. When coming to test the brakes i had the bleed kit on and was making sure all was fine when i seen a constant quick flowing drip. There was no pressure under the pedal at all. So i got a friend to pump the brake whilst i lay in the snow with my head under the car and i see the leak from the new caliper. theres a spring lever which the handbrake cable runs into and the spring has a washer were its connected to the caliper which was very loose. It was pouring out of here. Now i missed a days pay from work and im having to take a half day pay cut so i can get replacement caliper and get it changed. :bad-words: Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted December 22, 2009 I bet you were cursing! Hope you sort it soon Quote Share this post Link to post Share on other sites
