mort1414
left front wheel judder help
started about a week ago gets worse with more speed and gets better as the car warms up
video at slow speed
the abs light is on because the front left cable needs replacing just dont really want to do it in this weather and my coolant lite is flashing because i just fitted a mk4 expansion tank but need to wire it up.
could it still be the abs affecting something like?
  CorradoVR6-Turbo said:
when the abs lights is illuminated the ABS is non fuctional. that would not cause that sort of fault.
very true ignore my comment
go outside,jack up one front side at a time and look at the tread while rotating the wheel,you will find the trye deformed,or has a distinctive high spot.
just had a quick look and found a 'bleb' on the inside of tyre on the wall so cheers CorradoVR6-Turbo new tyres will be ordered shortly
any idea wat cause these there 35 profile so hope the alloy is ok
mort
