el_cappytan
Fuel Pressure
actually just thinking about this, the pump is capable of delivering .5gpm at 100psi, but pump/ fuel distributor line pressure should be around 70psi.... i think!
and that said, pumps only create supply, restrictions in the system create the pressure :)
Well that does make sense!! I just need to check its still performing properly as i dont want to starve the new 20v of fuel before i've even driven it!! :D
20v injectors won't need that kind of pressure, no nothing about transplants, but would think you'd have to restrict the supply pressure to suit
its more about flow rather than pressure,but a standard valver fuel pumps are know to delever plenty of fuel upto 350hp mark but dont quote me on that.
20vt will be 3-3.5 bar at the rail.
I'm bumping this thread instead of starting another one.
Are the figures quoted above for the intank fuel pump + the inline pump?
Does anyone know if the intank pump will supply a 20vt with enough flow/pressure without the inline pump?
I'm removing the inline pump and need to know what intank pump i can use.
cheers,
Paddy
