nelds 0 Posted January 20, 2010 7x16 fronts and 8x16 rears et52 offset. the front are 205/45/16 falkans and the rears are 225/40/16 falkans. would i need arch work and will the offset allow for adaptors...? Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 20, 2010 adapters or spacers? those wheels should fit fine, depending on how low the car is really Quote Share this post Link to post Share on other sites
nelds 0 Posted January 20, 2010 they're Porsche fitment so it'll be adaptors.......looking to run coilovers unless i can get away with just lowering springs, what drop can i get away with on those rim sizes ?? Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 20, 2010 are they 7 slots? dunno the exact mm but this low :lol: no rubbing 25mm adapters Quote Share this post Link to post Share on other sites
nelds 0 Posted January 20, 2010 i think they're D90's i'm looking to get. what size rims are you running there..???.....are they called 928 winters or something..? Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 20, 2010 they were 928's yea but 7x16 all around on coilovers with about an inch left still to wind down Quote Share this post Link to post Share on other sites
nelds 0 Posted January 20, 2010 what's a fairly decent coilover to use ?? Quote Share this post Link to post Share on other sites
Kempy 0 Posted January 20, 2010 could say really I got a mix of cheap and nasty ones. there is a huge thread on suspension, easy to find Quote Share this post Link to post Share on other sites
Bruceybaby 0 Posted January 20, 2010 I'm running the same setup on my rado with d90s. i had quite a problem with the 8's when i wound the coils down. so if your getting coilovers. remove the helpers when you fit them, as this is where i was fouling. i use 20mm adapters and there was also quite a bit of scrubbage on the inner arch . . . . . raised it a touch and all fine now! the fronts were fine on 7. Quote Share this post Link to post Share on other sites
nelds 0 Posted January 21, 2010 any pics of your ride with this set up..? Quote Share this post Link to post Share on other sites
