Swompy 0 Posted February 5, 2010 How easy is it to replace the top mounts and how do you do it? This si the state of mine at the more Drivers side Passenger side Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 5, 2010 they arnt too bad to do, easier on a 2 post ramp, and a 4wheel alignment would be recommened, as thre strut would need to come out! depends how mechanically minded you are? :D Quote Share this post Link to post Share on other sites
Swompy 0 Posted February 5, 2010 volksworld13 said: they arnt too bad to do, easier on a 2 post ramp, and a 4wheel alignment would be recommened, as thre strut would need to come out! depends how mechanically minded you are? :D Not really is the answer to that, so not really a DIY job then :( Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 5, 2010 its difficult to say im a mechanic, but if you are unsure, then a garage is the only way. Quote Share this post Link to post Share on other sites
Wompa 0 Posted February 5, 2010 That not hard... Im not a expert mechanic but did this work when I changed to my coils. Just lift upp the car, let the wheel touch the ground so it dont just fall down. Unbolt the two bolts for the shock down on the hub and then the top bolt, and then lift up the car so that the shock can be easly removed. Easy peasy! Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted February 5, 2010 Blake services in Stroud did mine before- disn't take them long at all- give 'em a call :) Make sure you put VW mounts on, pretty sure you can put VR6 ones on- worth doing especially as you're changing the suspension soon ;) Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 5, 2010 to be honest if you have basic mechanical skills, then give it a bash, if you get stuck, just pm me, but as the wompa sed, 2 bolts for the strut, top mount bolt and remove, i used a special ratchet through with allen key in the top to stop the it from spinning whilst undoing the top strut nut, hope this helps. Quote Share this post Link to post Share on other sites
Swompy 0 Posted February 5, 2010 CazzaVR said: Blake services in Stroud did mine before- disn't take them long at all- give 'em a call :) Make sure you put VW mounts on, pretty sure you can put VR6 ones on- worth doing especially as you're changing the suspension soon ;) Ya just going to put some half decent used ones on for now then get new ones when i get everything els done. How much was it Andy? if you can remember Quote Share this post Link to post Share on other sites
rob1234 0 Posted February 5, 2010 Think I'm going to try these poly ones next time I need to: http://cgi.ebay.co.uk/VW-Golf-MK3-Front ... 1695wt_941 Thoughts? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted February 5, 2010 Jake, don't bother using secondhand bits- total false economy, especially with rubber parts! Just wait until you can afford to do it properly- much less hassle. Can't remember how much it cost- wasn't that much- an hours labour + parts. They are very good on price + they sourced the genuine parts. Tell him I sent you ;) Quote Share this post Link to post Share on other sites
Swompy 0 Posted February 5, 2010 CazzaVR said: Jake, don't bother using secondhand bits- total false economy, especially with rubber parts! Just wait until you can afford to do it properly- much less hassle. Can't remember how much it cost- wasn't that much- an hours labour + parts. They are very good on price + they sourced the genuine parts. Tell him I sent you ;) Ya thats a fair shout can you pm me the number please Quote Share this post Link to post Share on other sites
Jonny777 0 Posted February 5, 2010 I've done it countless times now on various cars, Mk2's and my Rado etc. Fairly easy really. :) Just as long as you've got somewhere to do it! Make sure you buy VW items though, rest are sh*te. Quote Share this post Link to post Share on other sites
