ross.taylor 0 Posted January 23, 2004 Have recently got a new rear wiper motor to sort the "broken washer pipe attachment" problem. I was under the impression that the washer is supposed to move with the wiper. But this one stays pretty much pointing straight up the screen. It moves about a bit when the wiper moves - somthing like 5-10 degrees. What happens on other cars? Quote Share this post Link to post Share on other sites
VR6 0 Posted January 23, 2004 I would've thought it moved with the wiper. Otherwise, the wiper will get in the way of the water jet everytime it sweeps. Quote Share this post Link to post Share on other sites
stevef 0 Posted January 23, 2004 Mine was blocked recently. I don't think it moves, it points straight up the middle of the window. The washer jet comes in 2 parts, a long plastic tube with an elbow goes in from the bottom and a smaller pipe with the jet in it goes in from the top (after raising the plastic cover). They come out OK if you give them a firm tug. But I am sure they don't turn with the wiper. Stevef Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 23, 2004 Yeah the washer jet is fixed, hence the cut-out around the circumference of the wiper hinge. Quote Share this post Link to post Share on other sites
G60Jet 1 Posted January 23, 2004 The jet moves about 10-20 degress on mine, i think they are ment to, all VAG cars have the same rear wiper system. Quote Share this post Link to post Share on other sites
