PeteL
Aerial Base Seal
Guys
I have done a search on this and all teh results are either rather old or not clear.
I am after the rubber seal at the base of the areial on the roof.
Where can I get one of these as a separate part? If you can? I have read ebay and VW are places to go but I am after some more recent info.
Not 100% on this mate, but I've been after one for a while, and secured one t'other day via here!
Here's probably ur best bet :)
I also managed to get one from here, I paid £15 brand new. I believe it used to the case that you could only buy the whole base from the stealers for roughly £80 but I think someone also posted a part number for just the part you are after. Do a quick search, and maybe check ETKA?
EDIT - Just done a search and looks like VAGparts used to do a kit:
Cheers for the help guys, I've also found the repair kit on VAg parts - £10.95 instead of £60 plus at the stealers.
But they're long gone now :(
Guys
I bought one of these, as recommended by someone on the forum - Fits a treat
http://cgi.ebay.co.uk/Seat-Arosa-Ibiza- ... 5d24cd3c56
Ian :D
Thanks Guys
Ian - I have ordered one and will post up how I get on.
Otherwise looks like it getting one off here.
Guys
Ian :D
Wow, that looks exactly like the one I got from here for £15! Should've asked first! :lol:
Thanks Guys
yep, I got one of these too. Despite fitting OK, it looks like it's 1 or 2mm loose...
Guys
Ian :D
Also just ordered one of these. Even if it doesn't fit properly its got to be better than the one which is clinging on now.
Fitted this now and 99.9% matching fit. Cheers
Glad you are pleased with it, mine is a massive improvement on the one that was previously fitted.
Ian.
