muppetlab
Vr abs warning light wiring
After months of having the dread light on all the time i finally cured the faults and managed to get the abs to work. Unfortunately this was not before the mot so the light was disconnected for the mot. failed on a brake hose anyway. So sorted all out and went to plug the abs light back in and now it wont light at all even with just ignition on. does anyone know what the wiring for it is, there seems to be some sort of circuit board in the switch but i am not sure how to test it? Are there any pins on the switch i can bridge to see if the bulb has gone? Also if the light is faulty would this disable the abs? thanks for any help.
Thanks i already tried across the bulb terminals but i got about 10v and the bulb wasnt lighting. Tried an led instead but it wont light up? There is power to a couple of the plug terminals. The abs actually works just been out and tried locking the wheels up. Will try a replacement light, maybe the circuit board is buggered or something? cheers jez
