ray_vr6 1 Posted March 2, 2010 Hi Recently fitted two new door handles and the drivers one is not fitting snugly against the outer door skin i.e. when I use the handle there is a slight amount of play when I pull on it. It has the gasket fitted and the securing screw is tightened ok Anyone had a similar problem? Thanks In advance Quote Share this post Link to post Share on other sites
shaung60 0 Posted March 8, 2010 You got both the black gasket and the C shape white one fitted? Quote Share this post Link to post Share on other sites
ray_vr6 1 Posted March 9, 2010 Hi Don't recall seeing any C shaped white gasket when I removed the old handles. Where abouts does it get positioned? Cheers Quote Share this post Link to post Share on other sites
shaung60 0 Posted March 9, 2010 Here you go... P3090881.JPG[/attachment:1brkm7o2] Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted March 9, 2010 You can still get these for a few p from VW ;) Quote Share this post Link to post Share on other sites
ray_vr6 1 Posted March 9, 2010 Thanks guys - defo not got these so will pay a vist to local VW dealer Quote Share this post Link to post Share on other sites
John-M 0 Posted March 12, 2010 I have just had to repair my nearside door handle ( the usual problem ) using Daves16v's repair kit - excellent wee kit, btw :) Got it all back together and installed in the door, then found that white clip ! Is it supposed to clip in to where its shown in shaung60's picture ?? It just seems to rest there, not located by anything :( Quote Share this post Link to post Share on other sites
John-M 0 Posted March 14, 2010 Worked it out - the white 'clip' fits inside the aperture in the door and the handle locates into it. Shimples :) Quote Share this post Link to post Share on other sites
dragon green 6 Posted March 15, 2010 Part number 357837242 25p In stock,as it fits many models Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 15, 2010 My drivers side is a bit wobbily that clip must be missing on that side as it has been off before will get one from VW cheers Whats it called?? clip?? Quote Share this post Link to post Share on other sites
John-M 0 Posted March 16, 2010 Its referred to as a clamp - and the part number above is correct. Most likely in stock at the dealers. Quote Share this post Link to post Share on other sites
James. 9 Posted March 16, 2010 I bought some from the dealer a couple of weeks ago so should be good for stock. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 16, 2010 :clap: cheers lads Quote Share this post Link to post Share on other sites
dragon green 6 Posted March 16, 2010 I bought mine last night,the first "off the shelf" parts ever !! :eek: Quote Share this post Link to post Share on other sites
Neilalexb 10 Posted April 29, 2019 Hi How do I fit a drivers door c lip to a corrado please help? Cheers Quote Share this post Link to post Share on other sites
