VR6_ROB 0 Posted March 6, 2010 this is proberly a question that has been asked a thousand times my rear spoiler on my g60 goes up on the switch but wont come back down I have to put it down manually from inside the boot does anybody know the cause also the sunroof only tilts but it attempts to slide maybe moves a few mm then it sticks is this a chew on to fix my mk2 golf was a nightmare to do Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 6, 2010 spoiler is fixed i took it all apart, one of the buttons on the small blue microswitch is jammed inside it does anybody know where i can get a new microswitch they must be pennys to buy Quote Share this post Link to post Share on other sites
volksworld13 0 Posted March 6, 2010 i dont think yo can buy these seperate , try the dealers, but im sure the motor went obsolete years ago, i have a ful spoiler mech for sale if your interested. Quote Share this post Link to post Share on other sites
volksworld13 0 Posted March 6, 2010 viewtopic.php?f=13&t=88511 Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 6, 2010 cheers bud my mate is a sparky he is going to see if he can get some switches from work first if he cant get any and you still have it i might have it off you cheers rob Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 11, 2010 I refitted the limit switches i bought from maplin bingo everything started working but it was going up in stages not sure if this is normal anyway i put all the mechanism back into the boot tried it it went up but would not come down had a look the spoiler was not striaght so i wound it down and refitted the spoiler now it does nothing could i of blown a fuse?? if so which one is it Quote Share this post Link to post Share on other sites
volksworld13 0 Posted March 11, 2010 yes you may of blown a fuse, remove the driver side lower shelf and check the fuses, the spoiler fuse should be shown on the back of the cover shelf. check here 1st. Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 12, 2010 it is not shown on the fuse box cover i dont fancy taking the all the fuses out 1 by 1 anyone? Quote Share this post Link to post Share on other sites
millerman 0 Posted March 12, 2010 have you fixed your sunroof ?? Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 12, 2010 not had a go at the sunroof yet it tilts but wont slide back something is jamming it Quote Share this post Link to post Share on other sites
millerman 0 Posted March 12, 2010 im sure you can get a repair kit and normally its the cables that go if i were you i would be on the look out for a moon roof from a passat they are a doddle to fit and the mech's are more reliable and less complex than the corrado ones Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 12, 2010 i might look out for one what model passat are they on? I have just checked the fuel pump fuse as somebody said the spoiler runs on it it is not blown not sure whats happened to it i will need ot strip it down over the weekend cables might be stuck its quite stiff to move manually now Quote Share this post Link to post Share on other sites
millerman 0 Posted March 12, 2010 i might look out for one what model passat are they on? I have just checked the fuel pump fuse as somebody said the spoiler runs on it it is not blown not sure whats happened to it i will need ot strip it down over the weekend cables might be stuck its quite stiff to move manually now b3 estate you can also use seat toledo 96 to 98 Quote Share this post Link to post Share on other sites
VR6_ROB 0 Posted March 13, 2010 had the spoiler in bits today and the mechanism one cable was not set level with the other one and a fuse had popped its the warning light fuse, so i changed the fuse while it was in bits and it worked greased the cables up put it back together does not work now the motor is solid cant pull the switch out to move it manually so i stripped it again plugged the motor in and tried it it only moves one way now I am sick of stripping it down is a wiper motor the same?? I have a spare off my mk2 golf kicking around at home Quote Share this post Link to post Share on other sites
