A5 VRX
Part No request please...
The guide pins that the caliper sits on are 251 615 219, £15 each, although confusingly Etka lists "1 set: guide bushes" as the pin and the plastic bush for £12 each :cuckoo: 4D0 698 647.
The bolts that hold the caliper carrier to the hub are N 907 085 02 £2 each.
i was told by someone on here back when i did mine that you couldn't buy them from VW, or you have to buy the whole caliper or carrier to get them.
would be interested to know the answer you get.
That't the pins for the 280mm setup and the rear carriers, the 288 / 312mm ATE setup is different.
