VR6_ROB
not a corrado
thought i would post up my other project its not a corrado im afraid
had it a few years now to many pictures to put up so I will just put up the latest pictures
still a long way off yet to complete but it wont be long
anyway heres some pictures let me know your views on it
need to raise the car up slightly rubbing on the rear
http://img.photobucket.com/albums/v229/Rob119/P280310_1026.jpg[/img
Very nice... would love to see some more updates as this one comes along :)
little update today
got all the hoses plumbed in throttle body needed re-painting to never got managed to fit that
few brackets here and there
rad and fans fitted better
strut brace bolted on
lights fitted although the grill wont sit right on one side
heres one side sat nicely
heres the other side sticking otu slightly
also does this look normal or should it be sat back a bit more at the top
heres the rest of the pics from today enjoy see what you think nearly there now
turned the brake fluid resovoir around so the strut brace does not get in the way
and i need to find a way to mount the header tank might make a bracket to fit from the strut brace
From what i remember from my mk2 owning days, the top of the grill does protrude slightly more than the bottom, so yeah, i think its normal.
Sweet looking mk2 with the perfect engine of choice.
lovely mate, really nice
and the grille is fine, all the mk2's i've had have been like that so it must be normal.
your front wings need adjusting to get the grill in... have you tried placing the bonnet (very, very, very carefully!) into location yet? Bet that the panel gap down the sides is closer at the front than at the rear... ;)
Grill should sit out further at the top than at the bottom, so that's pretty normal...
Nice looking project this... 8) although a white engine is gonna be an utter **** to keep clean! :eek: You could get an under-tray from a GTD MKII Golf which'd stop road crud getting into the bay and keep it somewhat cleaner though... ;)
had a nightmare fitting the doors today pretty difficult to do on your own
but there on anyway looks more like a car now
having a hard time getting the door handles to fit properly i bought some porsche door seals
still to small i think i need to cut part of the door to so they go on flush
anyway heres a couple of pictures i took wing is not lined up properly need to adjust it when i get a minute
