carrots 1 Posted April 4, 2010 has anyone fitted electric window door cards to wind up window doors, no electric windows on mine :( Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 4, 2010 a lot of early 16v cars had this done at the dealership, there's a set of aftermarket switches that don't need the window control box (saves on a lot of wiring) which look similar to the early VAG switches but have an extra connection to allow permanently live wired windows. This is the simlest way of converting, you could then add a relay linked to the ignition live if you don't want live windows with ignition off. some passats were fitted with this aftermarket kit, so you might be lucky and find a set from a breaking passat if you can't find corrado ones (switches the same) what you need are the early style switches, but ones without the plug in connector blocks on the back, just directly soldered. the other alternative is a complete loom and control box and plug type switches from a factory electric window system. window regulators from any electric-window-car will do, regardless of the route you take to wiring them, they just need riveting in place. Quote Share this post Link to post Share on other sites
stretch. 0 Posted April 8, 2010 I think mine had this done, along with some more bodging... I can get you some pictures later if that's any help? Quote Share this post Link to post Share on other sites
