DarkVR6 0 Posted April 13, 2010 hi i had a small leak on the sump and decided that i would replace the sump gasket. once the sump was removed, i inspected the oil pump and cleaned it with a cloth, i noticed some plastic bits falling from inside the pump pick up hole, it has mesh lining behind it. i am about to put it back together and was wondering if its worth replacing the pump? or shall i clean the plastic bits away and re use it? obviously i dont want to put it back if its going to damage the engine. cheers for any info. corrado vr6 93 kreg Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 13, 2010 What colour are the plastic bits? Red = Bits of snapped dipstick mount fell down the tube. Brown = Bits of upper chain tensioner have fallen into the sump. You will need to schedule in chain replacement pronto. Any other colour = :shrug: Pump is fine to reuse, they are very robust on the VR6. Quote Share this post Link to post Share on other sites
DarkVR6 0 Posted April 13, 2010 the bits are black in colour and i only discovered them when i put my finger in the pump hole to clean it out with a cloth and the plactic bits dropped out, some are still in there, looks like the heat may have made this part brittle and it only took a little pressure to shatter it. Quote Share this post Link to post Share on other sites
