fendervg
Glovebox lid question
Maybe someone can help - do the two plastic guides that hook the lid into the glovebox body on each side just pull out or is there another trick to it ? Trying to fit a brodit pro-clip phone holder and need to hook it under the side of the glovebox trim.
Many thanks,
I think you push them inwards towards each other with the lid half tilted and then the front flap should open completely. Or outwards. Either way, you don't just force it :D
Cheers - will try that - as in many things Corrado, especially trim related, force is not a good idea. Gently does it.....
