jpowell79
The definitive guide to ABS
Can anyone help with posting a definitive guide to ABS, and then perhaps we could have it as a sticky?
MY ABS light doesn't work - I changed the bulb, and cleared the codes with VAG-COM, but still no light, and to be honest I don't have a clue how to test (apart from driving very fast, and braking suddenly!)
does anyone have a step-by-step guide on the following:
1. How to test if your ABS is working (I recall something about turning the iginition key, and the light should come on, then go off after a few seconds?)
2. Which parts commonly go wrong with ABS - how to get to them, what they look like, how to check if they're ok?
3. Part numbers
4. Troubleshooting - component & electrical - which wires should we be checking, fuses, anything else?
Really want to get the ABS sorted out , but just don't have a clue where to start! :confused4:
Some helpful information on common ABS faults here
Just pray that it is not your ABS brake pedal position sensor :censored:. See this thread
Its something that we all go through owning Corrados. I dont know much about the ABS system but getting your C hooked up to VAG COM would illiminate alot of wasted time. Putting your foot on the brake pedal whilst turning on the ignition key should induce a pulse which you should be able to feel on the brake pedal if the ABS system is working.
yeah I did have some fault codes relating to ABS on VAG com but deleted them and they haven't returned
the other thread suggested I look round and check the 4 sensors. Do I need to take the wheels off to access them?
anyone??
