1977amm
What does this bit do?
Please see photo below. Can someone help me please? I'd like to know..
1) what does this bit do? It's maybe not clear in the photo, but it's at the top left of the engine (as you stand facing the front of the car)
2) is it supposed to be as it is? (ie no longer attached) - I assume not
3) if it's not right what problems it might cause
4) how do I sort it and will any replacement parts be required?
Ebay items 002.jpg[/attachment:2y13turm]
All advice very gratefully received! Thanks.
Thanks for that. Now that I know what it is, I can search the forum.
Assuming I get the Ford part, is it easy for me to replace? I'm mechanically inept.
Also, will this have been having a detrimental effect on emissions? My car was going to fail its MOT on emissions, but didn't complete the test (alternator belt snapped). Is this likely to solve the probelm?
Thanks
Mine like many others has never had the valve, just a pipe going to the intake pipe. Oil does go back into the throttle body with no detrimental affect.
What's the best way to block this off?
I'm sure I've read that you should disconnect the PCV when using a charger.
