Steels1875 0 Posted May 18, 2010 Hello, I'm having major problems with starting my Corrado and wonder if it may be a fault with the meta system. When starting, engine will catch but then revs will die away immediatly and engine will cut out. I had to call AA who put it on the back of a lorry and took it to a garage, and once there removed it from the lorry and i tried it again and it worked!! It will then start no problem for the rest of the day, however the next morning i had the same problem!! very frustrating!!! any help/advice would be much appreciated Thanks Quote Share this post Link to post Share on other sites
MikeVR6 0 Posted June 12, 2010 It might be the built in VW immobiliser. The "reader coil" around the ignition barrel can go and cause your symptoms. Mine went last summer. I traced the connection for the coil back to a little plug behind the dash near the headlight switch. Pulled the plug off, sprayed some contact cleaner around both connections, gave them a good scrub. Reconnected and the problem disappeared. Search for "reader coil" for more info. Quote Share this post Link to post Share on other sites
