deanpompey
will i need to roll my arches???? 9x16 et15 on rears..
picking up some Borbet A's tomo in 7.5 et20 and 9 x 16 et15.
car is on coils so can be raised a touch if necessary, currently down around 80-90mm on 15x8j et 25 Th Monos with no rubbing issues etc, but not sure what ill need to pull off the A's.
cant confirm tyre sizes until tomo...
anyone have these on their Rado an wanna give me a clue?
I had it lowered by 6cm a while ago with 9's brock b1s and there was about 2cm between tyre and rear arches :nuts:
depends if its a vr6 or not. if vr6 yes most definately otherwise you will have to run it quite high, if its not then you can get away without rolling but it may rub if you want to run it low. For the best look and functionality i would say yes, my tyres suffered a bit of a beating on my old car when i was running borbet a's with unrolled arches
its an early valver.
fronts are 7.5 Et 30 tyres 195/45/16
rears are 7x 9 Et15 tyres 205/45/16
fronts are ( i think ) catching on the coilies, so gonna need a spacer (to be fair the 7.5's look lost in the front arches anyway so no prob there!)
rears i had to raise up a good 2cm, and are still catching :(
Arch roller being put to use ASAP!
gotta love this though....
