poll250 0 Posted June 7, 2010 Hi, I just picked up a set of 17" 7.5 ET35 RCs for the Rado as 2 of my OZ's are buckled beyond repair :( I was just wondering if they'd fit over my 312mm Brembos without spacers? Ta Quote Share this post Link to post Share on other sites
KADVR6 0 Posted June 7, 2010 probably not, as i needed 10mm spacers with my rc's and the 323mm brembos. Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted June 7, 2010 Disc size isn't the problem, its the calipers, will depend which ones you are using, I needed 13mm per side to clear mine, which were an upgrade Brembo for a S3 with 323 discs Quote Share this post Link to post Share on other sites
poll250 0 Posted June 7, 2010 Dang. 13mm is quite a lot! I'm using 7J OZ's at the moment with 10mm spacers - was hoping the extra 0.25 inch of these would be enough to drop the spacers as they are a very similar style rim. grrr. I guess I'll see in a couple of days, but I don't think my callipers are physically as big as Leon Brembos. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted June 7, 2010 hence i went for wilwood calipers,so much thinner and work brill! Quote Share this post Link to post Share on other sites
20vturbo 0 Posted June 7, 2010 i have porsche gt3 front calipers on 340mm discs under a set of bbs rc's 17" x 7.5 i can get away with a 10mm spacer but i went for 15mm just to be safe. Quote Share this post Link to post Share on other sites
poll250 0 Posted June 7, 2010 Me thinks I should have started this thread before paying for them! Quote Share this post Link to post Share on other sites
KADVR6 0 Posted June 7, 2010 Me thinks I should have started this thread before paying for them! you will be fine, i had 12mm spacers front and 15mm rear with standard arches and the TX's set firm, and had no rubbing in the 18 months the brembos were fitted. Quote Share this post Link to post Share on other sites
DANG60 0 Posted June 7, 2010 hence i went for wilwood calipers,so much thinner and work brill! Do the willwoods have dust seals on them? Sorry for hijacking but has anybody ever used bremsports as they are also a thinner caliper. I know the guy with the black cover car rallye from pvw used bremsports on his. I had 305 brembos on my last one and the calipers seem to be big compared to other makes Quote Share this post Link to post Share on other sites
