g6tgazc 0 Posted June 15, 2010 Hi there, the headling in my Corrado is very tatty so was thinking of replacing it but is it a big job to remove/swap?? Cheers Quote Share this post Link to post Share on other sites
yacobwood 0 Posted June 15, 2010 Did this not long back. Its a trick job as the headlining is VERY thin. Its held in by the seal around the sunroof and various trim pieces around it (Sun visors, ABC pillars, rear trim). We removed most of the trim, held the ABC pillars down and slid it out of the boot. Not sure if this is correct but it worked for us :? Quote Share this post Link to post Share on other sites
shaung60 0 Posted June 15, 2010 Did this not long back. Its a trick job as the headlining is VERY thin. Its held in by the seal around the sunroof and various trim pieces around it (Sun visors, ABC pillars, rear trim). We removed most of the trim, held the ABC pillars down and slid it out of the boot. Not sure if this is correct but it worked for us :? That's the way I do it too. Quote Share this post Link to post Share on other sites
fla 9 Posted June 15, 2010 how do you remove the sunroof trim? I'm afraid of bending this or putting irreversible kinks in it :shrug: :shrug: Quote Share this post Link to post Share on other sites
yacobwood 0 Posted June 15, 2010 it just pushes on. its very tight tho Quote Share this post Link to post Share on other sites
fla 9 Posted June 16, 2010 OK thanks. Does it pull out horizontally or vertically? Quote Share this post Link to post Share on other sites
yacobwood 0 Posted June 16, 2010 horizontally. getting it off is easy. getting it back on is tricky. its like the black door seal. always seems too long to fit :censored: Quote Share this post Link to post Share on other sites
g6tgazc 0 Posted June 16, 2010 Did this not long back. Its a trick job as the headlining is VERY thin. Its held in by the seal around the sunroof and various trim pieces around it (Sun visors, ABC pillars, rear trim). We removed most of the trim, held the ABC pillars down and slid it out of the boot. Not sure if this is correct but it worked for us :? Cheers, thanks!! If i decided to take the A,B,C pillar trims off do they just pop off or what, I was afarid of breaking them!! Quote Share this post Link to post Share on other sites
yacobwood 0 Posted June 16, 2010 Ive never taken them off tbh. Some Corrado guru on here might help there :) Quote Share this post Link to post Share on other sites
KipVR 1 Posted June 16, 2010 There's a few covered screws and then just pry it off. Quote Share this post Link to post Share on other sites
fla 9 Posted June 17, 2010 horizontally. getting it off is easy. getting it back on is tricky. its like the black door seal. always seems too long to fit :censored: thanks for that - car was boiling inside today, which meant the trim piece came off more easily, the rubber was nice and pliable. You're right though, it was still pretty tough to remove, looks like some adhesive was used around the join as the rest just pulled off nice and easily. Quote Share this post Link to post Share on other sites
