joshyp 0 Posted June 20, 2010 The sun roof was dragging the lining of so i removed it, then the sunroof wouldnt fully close(1cm) so gave it a little push while holding button and it shut. now it will only go up and down slighty before stopping. what have i done ??? *how do i get to everything? remove cover.... how? * new headlining just around the sunroof. not centre piece the thin outer strip!2.8l 24v Climatronic system.pdfIMG_0726[1].JPG[/attachment:2dn58kz1] Quote Share this post Link to post Share on other sites
joshyp 0 Posted June 20, 2010 ahhhhhh..... dont no what to do, i have been playing with it for ages and i will break something soon Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted June 20, 2010 Where are you ? Quote Share this post Link to post Share on other sites
joshyp 0 Posted June 20, 2010 somerset! why can u help? Quote Share this post Link to post Share on other sites
shawshankkid 1 Posted June 20, 2010 I could if you were a bit closer to me...somerset is too far for me to help sorry. Ps...Always best to put your location in your profile so it shows next to your name and avatar. Cheers, Chris. Quote Share this post Link to post Share on other sites
James. 9 Posted June 20, 2010 When you say removed it. Do you mean the complete sunroof ? Sounds like the best solution would be to remove the complete unit. Remove the motor from the sunroof and ensure it's at the closed position. Ensure all the linkage is pushed forward at the closed position and put it all back in. Sounds like a massive undertaking but should only take a couple of hours end to end. Quote Share this post Link to post Share on other sites
TimDoc 0 Posted June 20, 2010 where in somerset - anywhere near bath?? If so PM me and we'll sort out your roof! T Quote Share this post Link to post Share on other sites
joshyp 0 Posted August 1, 2010 bath is not a million miles away? i can travel Quote Share this post Link to post Share on other sites
TimDoc 0 Posted August 1, 2010 when can you come up?? I have a lot of time off at the mo! Quote Share this post Link to post Share on other sites
