holeinmk1 0 Posted June 24, 2010 Hi, do the later style clocks fit in an early model, is it pretty much plug and play or there more to it? the only reason i ask is i really want (one day, when i find a set) the gauge pack which sits in the centre console, i think it was an option on later vr6's? It looks really good,but mirrors the later dash, so would look a bit at odds with the gauge pack. Also anyone have any idea how hard to find they are,i'm guessing very! Cheers, Tom :) Quote Share this post Link to post Share on other sites
Reggit 0 Posted June 28, 2010 If you mean you want to fit the aux gauge panel with the oil/volt gauges - then they won't fit an early dash as the cubby hole is a lot smaller in the early one. There was a version for the early dash which was a plastic panel with 2 52mm holes for round gauges. Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 28, 2010 no, not a plug and play job, the connectors are different IIRC, it can be done, but I'm not sure if you could get the left/right indicators working as the early loom only feeds to one flashing light for both indicators. Quote Share this post Link to post Share on other sites
holeinmk1 0 Posted June 28, 2010 Oh right, well i can lay that idea to rest for now! It seems the early gauge holder is easier to find as well, i've found a few on ebay and i have some vdo gauges knocking around as well. Cheers guys. Tom Quote Share this post Link to post Share on other sites
