Akinesis 0 Posted June 25, 2010 Now then, now then... I'm a complete Corrado noob so pardon my ignorance! After giving up trying to find a 'clutch cable' (I've owned a Scirocco's for the last few years) I decided that my search was futile and 'that pipe there' must mean the Corrado's clutch is hydraulic. After searching on here I see that it is! Why would it be squeaking? It happens mostly when it's almost fully depressed and is quite loud. It's not metal squeaking - def plastic/hard rubber. Anyone got any ideas? Quote Share this post Link to post Share on other sites
fendervg 33 Posted June 29, 2010 Check the plastic trim that covers the top of the pedals under the driver's parcel shelf - this is located with a plastic screw type thing right at the front of the footwell and if not seated properly will cause the pedal arm to rub when depressed/released, making a noise - cheap easy fix if it is this. Next check the clutch release bearing - the gearbox cover plate has to come off to check this. Quote Share this post Link to post Share on other sites
Akinesis 0 Posted June 29, 2010 I will try this. Many thanks :grin: Quote Share this post Link to post Share on other sites
