fla
slam panel squeak, what do you use?
This has annoyed me since i got the car - the slam panel tends to move whenever the road is a little rough and squeaks like an old chair. What have people, used bbetween the panel and the mounting points? I initially used some pvc (electricians) tape but this didnt last too long, plus one or two of the bolts dont tighten up much. Its just the top ones, plus the two behind the lights which cause teh problem, the main load-bearing ones lower down are fine.
well its only taken me 6 years of corrado ownership to work out the real source of the noise :shrug: - the aircon evaporator against the rad, so some thin neoprene pads will solve this....hopefully.
