rmn
Alignment on a corrado
does anybody have, or know where i would get the measurements to check the alignments!
I know my project was whacked, but before it goes to the body shop i want to make sure the shell is reasonably straight!
Thanks
Well:
Front strut tower centre distance = 1087mm.
Front chassis leg seperation = 935mm (measured at front inner edge, at the mid point curved strengthener)
Door aperture = 1100mm (measured horizontally at the widest point)
Rear strut tower centre distance = 1107mm
Tailgate aperture = 1094mm (measured horixontally at widest point)
Tailgate aperture = 950mm (measured on body centreline)
B-pillar seperation = 1374mm (measure horisontally at the rear edge of the door aperture)
HTH.
Thanks Mike, does the B pillar seperation get measured at the base or not?
Its Around the sills and b post i am curious about
The widest point should be near the mounting for the lock pin on the pillar - about half-way up.
There are a load of measurements given in the Bently manual for the underside of the chassis, but no easy way to describe them.
