timmaaah
Mirror control switch led - what voltage?
I've looked and looked and looked and can't seem to find a definitive answer.
Are the leds in the late mirror control unit 2volt or 12volt? Half the stuff I've read says one thing and the other half says otherwise :cuckoo: :cuckoo:
I've read through the ccc guide, and there's two voltages mentioned in there, and the guide on here also refers to two different voltages (2/3v or 12v!)
Looking at the insides of the switch, it would appear that the leds are wired in parallel, and a multimeter across the terminals reads 12(ish) volts, so I assume they should be 12volt.
Please can someone give me a definitive answer....please :)
12v 3mm needed for these, and yes they are all in parallel.
