big ben 10 Posted August 4, 2010 i need to move a heated loom and switch out of another corrado to mine. Is there a simple way? i have been putting it off for ages and really need to have a look and get it sorted soon Ben Quote Share this post Link to post Share on other sites
JMC 0 Posted August 4, 2010 Take the carpets up unfortunately... Quote Share this post Link to post Share on other sites
big ben 10 Posted August 4, 2010 cheers. i have done a carpet change before so i was more concerned about the switch in the dash, havent ever taken the dash out so was wondering if i had to? Quote Share this post Link to post Share on other sites
JMC 0 Posted August 4, 2010 If you take out the cowl around the instruments - 4 screws, you should be able to get enough clearance to get the switch out. Then you need access to behing the fuse box - underdash tray out, and rotate the fusebox down to reveal where it is plugged in. Just one wire from memory there. You don't need to take the dash out to do this. Quote Share this post Link to post Share on other sites
big ben 10 Posted August 4, 2010 thats what i wanted to here, thanks bud :salute: means i will be having heated seats for this winter again :grin: Quote Share this post Link to post Share on other sites
JMC 0 Posted August 4, 2010 You're welcome. Bit of a fiddly job, just take your time. Quote Share this post Link to post Share on other sites
8vMatt 1 Posted August 4, 2010 I need to install my heated seat loom in time for the winter. Does anyone have any pics of what goes where and which bit to connect to in the fuse box. I'm hoping I've got the full loom, as it just looks like a jumble of wires. Got the seat plugs, relays, dash switch plus a load of extra wires that don't go to anything! Hmmm. I know about the relays going behind the passenger doorcard, its just the fusebox bit I'm not sure of. Cheers guys. Quote Share this post Link to post Share on other sites
JMC 0 Posted August 4, 2010 How about this.... http://www.the-corrado.net/.archive/forum/viewtopic.php?f=19&t=76368&hilit=heated+seat+loom Quote Share this post Link to post Share on other sites
8vMatt 1 Posted August 4, 2010 Brilliant, doing searches on my phone is a right pain. I'll check that thread out. Thanks. Quote Share this post Link to post Share on other sites
big ben 10 Posted August 4, 2010 luckily for me im taking the loom out of my old VR and then just putting it straight in mine, so that makes life easier i suppose Quote Share this post Link to post Share on other sites
Portent 0 Posted April 9, 2012 How about this.... http://www.the-corrado.net/.archive/forum/viewtopic.php?f=19&t=76368&hilit=heated+seat+loom Reviving an old thread as I'm trying to find out which parts of the loom go where and the above is no longer accessible. Any assistance is appreciated. Thanks. Quote Share this post Link to post Share on other sites
somersetdub 0 Posted April 10, 2012 I did this a few months ago. I left the carpets in and worked around them, feeding the wires under where necessary. The relays go behind the passenger door card as already mentioned and the loom goes around the n/s of the car behind the dash to the switches and then I'm pretty sure it is just one wire that goes into the fuse board- the fuse board has quite a few spare slots and it just needs to plug into an ignition fed one. Quote Share this post Link to post Share on other sites
Portent 0 Posted April 10, 2012 Thanks that's great. I don't suppose you have any more information on the fuse box connection? From reading up it seems I need to put the black wire into a 12v feed and the grey into the ignition feed... but any idea which slots they are on the fuse box? Quote Share this post Link to post Share on other sites
somersetdub 0 Posted April 11, 2012 When I did mine I copied the way it was wired from the car I had just removed it from... But I believe the connections behind the fuse board are colour coded so it should just be a case of plugging each colour wire in its appropriate slot - ie there are empty slots ready for more accessories and some are grey, some black etc. If you are still unsure and don't want to risk it, run a test light to the slots to see when they power up to find out for sure. Quote Share this post Link to post Share on other sites
Portent 0 Posted April 11, 2012 Thanks. I think I've got my head around it. Quote Share this post Link to post Share on other sites
