Terencem215 0 Posted August 13, 2010 What Sensor records the mpg? and where can i find it, as the mpg reads 99.9 some times. and has anyone one had similar problems? And what sensor recognises the speed at which the spoiler goes up? The problem is, the spoiler wont raise automatically, but will manually via switch? thanx :salute: Quote Share this post Link to post Share on other sites
eugopnosaj 0 Posted August 14, 2010 its a vacuum tube for the spoiler afaik (someone correct me) and there is also one that plugs into the back of the dials, im going to assume that since neither work properly its the same tube...so if you can source where it comes from then maybe you can fix it... HOWEVER i could be totally wrong :lol: :nuts: Quote Share this post Link to post Share on other sites
