Cragel 0 Posted September 5, 2010 I don't know if I'm being a little thick here but I can't get the socket down the cylinder to remove the spark plug. The socket looks the same size as the ht lead nut will only go in a tiny bit, I don't want to force it then get it stuck. What am I doing wrong? It's a kr engine by the way. Thanks pepz. Quote Share this post Link to post Share on other sites
pummer67 0 Posted September 5, 2010 are you using a spark plug socket? A spark plug socket is deeper. If you are they normally come with some sort of rubber on when they are brand new and are a little stiff. Quote Share this post Link to post Share on other sites
Yandards 0 Posted September 5, 2010 There are 2 types of spark plug socket, you want the smaller diameter one. If you go to Halfords etc you can see the 2 different types. Quote Share this post Link to post Share on other sites
Cragel 0 Posted September 5, 2010 Yeah I'm using a 10mm socket. The smallest one. Quote Share this post Link to post Share on other sites
Toad 0 Posted September 5, 2010 Use a 3/8" drive socket, not the 1/2", otherwise they can foul on the rocker cover gasket part way down the hole. Last thing you want is to get the socket stuck in the hole. Quote Share this post Link to post Share on other sites
Cragel 0 Posted September 5, 2010 Ah ha! That's what's the problem then. I'll have to wait till Monday then and swap it at work. Thanks very much. Quote Share this post Link to post Share on other sites
