jimborae 0 Posted February 10, 2004 Ok I just found out how to measure my boost pressure using the MFA so can anyone tell me if they're ok. Its standard pulley but Jabba stage 4 when it was rebuilt 30,000 miles ago Idle 500-530 Full bore near redline in 4th- 1610 - 1730 (did the dual carriage way a few times) Thanks Jim Quote Share this post Link to post Share on other sites
mark28G60 0 Posted February 11, 2004 Jim, How have you measured it from the mfa can you write a description down as im keen to check mine thx Mark :evil: Quote Share this post Link to post Share on other sites
Tempest 0 Posted February 11, 2004 Simple: Engine off, then Press and hold MFA button, turn ignition key on and off again. Then start engine (still holding the MFA button), now release the MFA button. Set MFA to mode 2 (the measurement mode). Press the MFA button once to get the boost pressure on the display. Just for completeness: No. of times MFA button pressed: Display: 0------------------------------------------Checksum 1------------------------------------------Boost pressure 2------------------------------------------Revs 3------------------------------------------Momentary fuel consumption 4------------------------------------------Signal from speed sensor 5------------------------------------------Oil temperature 6------------------------------------------Ambient (outside) temperature OK, then once you've got the boost pressure on your display, one has to distinguish between Motometer and VDO instruments. Motometer instruments show pressure in mbar (again, there are 2 types, one will show absolute pressure, others the pressure above atmospheric pressure, i.e. above 1000 mbar), whilst VDO instruments show digital values: VDO Value: Motometer value (absolute pressure): Boost pressure delivered by G-Lader (above atmospheric pressure): 15--------------------------200--------------------------------------0 55--------------------------400-------------------------------------0 90--------------------------600--------------------------------------0 127------------------------800--------------------------------------0 148-----------------------1000-------------------------------------0 172-----------------------1200-------------------------------------200 192------------------------1400-------------------------------------400 211-----------------------1600-------------------------------------600 228-----------------------1800--------------------------------------800 242------------------------2000-------------------------------------1000 255------------------------2200--------------------------------------1200 Readings should be taken at just before 6100 rpm (after which boost pressure is reduced again), any boost reading of less than 211 (VDO) or 1600 (Motometer) should set the alarm bells sounding, i.e. time to take the G-Lader apart :( Hope this helps folks, Tempest Quote Share this post Link to post Share on other sites
