corrado_sunderland
central locking on one door failing, is this common?
one of the door of me rado will not unlock and even though all the other doors and locks now work it still wont, it used to work intermitently but after been stored a year will not work at all and im worried it will be hard to fix with door being shut and locks being flushed :( is this a common thing :confused4:
Take off the door card and see if your (orange?) pipes are connected to the white plastic vacuum box jobbie (got no idea what its called lol). If they are all ok, try replacing the white thing as this was what caused mine not to lock properly. Maybe swap it over from the side that works to save you buying one to test it.
