C5 OEM 0 Posted October 5, 2010 Have done one on my mk2 golf, any advice or tips for doing the corrado...? Quote Share this post Link to post Share on other sites
Guest Posted October 5, 2010 Can't help you there. My Kippax does mine :luvlove: But, from what I can see... after having removed the sunroof itself :eek: :shrug: it's a matter of pulling the old one off and pushing the new one one but it's a very firm fit and care needs to be taken not to damage the panel itself while applying enough force. Quote Share this post Link to post Share on other sites
poll250 0 Posted October 5, 2010 Is this the outer seal we are talking about? I've been thinking about doing mine soon as it's pretty perished. I was thinking you'd be able to do it with the sunroof still in, using a combination of different angles of tilt? Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted October 5, 2010 if you get it done this could be a good how to lol :wink: Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted October 5, 2010 ok then i`ll get it sorted and post up the pics Quote Share this post Link to post Share on other sites
Rams 0 Posted October 5, 2010 Will keep an eye on this as my new seal will be going on once the car is painted. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted October 5, 2010 exellent stuff can i ask where you got your seal from and how much mines all cracked and rubbish looking Quote Share this post Link to post Share on other sites
Rams 0 Posted October 5, 2010 got mine from TPS, they supply VW with parts direct. I get a discount as theres another vw group im a member off has agreed a deal. I can fish out the receipt if you like? Theres a picture on my gallery thread along with some other new bits.... Looks so much nicer, completely black and unperrished! Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted October 5, 2010 yea would be great to get rid of that old looking thing ill have a read of your thread now mate have a look and yea a price on one would be great Quote Share this post Link to post Share on other sites
RW1 0 Posted October 5, 2010 Don't forget to put the goo (not glue) in the seal gripping channel like we discussed at the Yorkie meeting Andy to stop the water running round the sunroof lid lip to the inside. I use brake caliper cylinder grease G 000 100 or Plastilube Brake Cylinder Lube as its a stiffer consistancy and does not easily move with water around. Or use VW's G 000 450 02 - Sunroof Grease. But equally if you have the panel out, you may clean and regrease the sliding tracks with VW's sunroof grease G 000 450 02. Do not use ordinary grease after cleaning. The grease is VW part number G 000 450 02. £19.17 plus VAT. Expensive but experience has demonstrated axle grease etc, cause problems with load on the mechanism. The seal will need to be cut to length so best to do a dry run and mark it. It contains a steel band so not easy to cut in situ but not hard either off the Corrado. Better to be a tad over in length and double check during the dry run that its home and firmly fitted before marking for the cut. The are not cheap so best to be sure. Seal joint is to the middle of the right hand side short length. . Quote Share this post Link to post Share on other sites
Rams 0 Posted October 5, 2010 yea would be great to get rid of that old looking thing ill have a read of your thread now mate have a look and yea a price on one would be great Here you go mate part no 321877209A £45.66 LESS DISCOUNT £42.01 PLUS VAT £49.36 Quote Share this post Link to post Share on other sites
James. 7 Posted October 5, 2010 £49.36 I honestly don't know how VW do it and make a profit :roll: Quote Share this post Link to post Share on other sites
Rams 0 Posted October 5, 2010 I hope you dont need new roof rubber strips! :) Quote Share this post Link to post Share on other sites
C5 OEM 0 Posted October 6, 2010 So i take it like the mk2 its a case of removing the internal panel and unscrewing the panel off the runners then take the sunroof out and fit seal off the car...? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted October 6, 2010 Yup, trick is getting the sunroof headlining back to gain access to the bolts. You need to raise the sunroof a little bit, then push back hard on the lining on the sunroof! Then you will be able to slide it into the roof cavity as if it was being slid back if you cant manage to do this you are too high with the roof and need to drop it a little more, it also helps to stand outside the car so you can push the lining down to clear the clips that the sunroof headlining slots into. :wink: Quote Share this post Link to post Share on other sites
