mistrall
heatr not working..
morning, well its getting cold now and a few weeks bck i had the heater matrix replaced due to it flooding the car, anyway since that incident the heaters doesnot heat the car - any common probs with this? thanks in advance x M
is the return hose warm pretty soon after the feed hose gets warm? (where the hoses go into the bulkhead from the engine bay)
If they are both hot then you may have a problem with your flaps :norty:
i feel like a pilot hehe, so where are the flaps? :shrug: :epicfail:
their usually hidden from view...
you'll need to whip the dash undertrays out and follow the heat/cold bowden cable down to the air distribution unit behind the dash, see if the flap is operating open/shut, hot water always flows though the matrix, no on/off valve, the heat is controlled purely from a flap opening/shutting.
ok after much thought and the garage telling me they would have to take the whole dash off to fix it, and also telling me i need to go to a breakers my sel;f to get the cable. i took the pasenger footwell bit out and withing 2 mins i have located the flap. i now have heaters!!!
