Scott-mk3 0 Posted October 22, 2010 Needing some help here. Have the same problem with both my corrados. They were both sitting off the road for a while and batteries drained. Had to jump start to start and now the stereos in both cars wont work. Thought might have been the radio fuse in the fusebox but this wasnt blown Any help appreciated. Quote Share this post Link to post Share on other sites
pumbaa 0 Posted October 22, 2010 Fuse in the back of the head unit? Quote Share this post Link to post Share on other sites
Scott-mk3 0 Posted October 22, 2010 Check all the fuses including the one on the back of the headunit. Still nothing. Took a voltmeter to the harness and only the direct feed is getting power but none to the ignition feed. Any ideas? Quote Share this post Link to post Share on other sites
warren 0 Posted October 22, 2010 maybe they require a code? if its a vw radio? Quote Share this post Link to post Share on other sites
Scott-mk3 0 Posted October 23, 2010 Both Alpine units and took them out and tried them in my polo and work no problem. Defo a problem with the car and not the unit. Anymore help? Quote Share this post Link to post Share on other sites
dannyboy 0 Posted October 23, 2010 wiggle the ignition barrel,see if its connection starting to loosen. failing that you can just connect the igintion wire to constant feed to get it working Quote Share this post Link to post Share on other sites
