AJ_EQ
VR6 Buying. Torque question.
HI guys. Sorry for the late reply, been pretty busy with work. Thanks for all the info, I've finally bought a gorgeous Bordeaux pearl VR6 and I love it. Over 3k, just the sound, wow!!!
thanks again.
  WigsVR6 said:
Would VAGCOM comfirm that the camshaft position sensor isn't working?
I'm told it doesn't always .. but mostly, yes. You may have to scan it before switching the engine off after a run.
Well done! You'll love it. Plus this has got to rate as one of the best forums out there for help with improvements/problems,
Enjoy!
thanks again.
  Quote
Thanks Dr Mat good timing with the reply as my VR is in the garage on Weds this week for an oil change after running in the engine for 1000 miles after some major engine work. I'll get my mechanic to do a full VAGCOM scan while its there.
