C. Will Corrado G60 2 0 Posted November 10, 2010 ... cleaning the car the other day and noticed one of the all red rear tail lights has a frosted appearance to it. Am I right in thinking the lacquer has gone in some way? How can I fix it? Can i just rub it down and re-apply some more lacquer? Don't really want to buy more, but also concerned I won't be able to match them up. Any help would be great. Quote Share this post Link to post Share on other sites
hombre_paulo 0 Posted November 10, 2010 Would also like to know this Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 10, 2010 Cloudy laquer usually points to a moisture problem. Either it was sprayed on in a cold / damp environment of the laquer has reacted to something, or doesn't like the cold. You can try a rub down with 1200 grit paper and polish up, but if that doesn't work you'll need to remove the red laquer and redo it unfortunately. Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted November 11, 2010 Thanks for the info, dam shame as it's only one corner! Quote Share this post Link to post Share on other sites
