fla 9 Posted February 2, 2012 Yes same stuff as in trainers Gaz, but quite a lot of it ie 500g of it in a good sized box too. Doesnt seem to do anything at all. Unless it needs to be heated or treated somehow first? Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted February 2, 2012 I use brake cables to check/clear the sunroof guides.. no problems at all.. you know youre all the way through when you can hear them in the wings! Just be gentle when prodding and you'll be fine, they are a harder plastic. Quote Share this post Link to post Share on other sites
fla 9 Posted June 10, 2012 driving the car when it was chucking it down last week and the interior was misting up quite a lot. Had the sunroof tilted to let out any moisture which helped slightly. Otherwise it seems to be fine. Usually use the aircon to dry it up but there must be some reason why this happens in the rain - obviously moisture ingress and subsequent condensation somewhere, or is this another corrado 'feature'? Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 11, 2012 My damp problem turned out to be a missing fixing plug for the rear corrado badge. Water ran under the carpet so the carpet itself didnt feel damp condensation especially on the rear screen was terrible until I found this, door seals were leaking a bit but the boot was the main issue Quote Share this post Link to post Share on other sites
