Rams 0 Posted November 20, 2010 Would anyone be interested in doing the OBD2 conversion for me if I can source the last item I need? I have the keys, transponder, manifold and throttle body/maf and engine ancilary loom. I'm not confident in doing the conversion myself but I make an excellent cup of tea usually accompanied by jammy doggers :D What sort of labour would I be looking at for everything to be fitted? Can remove the brake servo if needed before Quote Share this post Link to post Share on other sites
The_Dude 0 Posted November 20, 2010 The main beef is the loom mate. Bit of an arse from what I understand (especially if you get given an auto loom as I did...mass confusion until this was realised). Apart from that as far as I am aware, the rest is pretty straightforward, unbolt and replace. However I paid for someone else to do mine. Wasn't cheap but not bank breaking either. Quote Share this post Link to post Share on other sites
Rams 0 Posted November 20, 2010 Cheers dude, I read that you can update the late wiring and change plug ends but couldnt get any clearer advise.... The manifold etc I could happily do but I dont want to get the wiring wrong. The ancilary loom is simple enough to plug in. If I got a manual loom, is it a matter of plugging into fuse board and using those wires, plugging into the car? I though there was a fair bit of splicing and modifying on the loom and I know I would fudge it up, for sure. Quote Share this post Link to post Share on other sites
The_Dude 0 Posted November 20, 2010 Cheers dude, I read that you can update the late wiring and change plug ends but couldnt get any clearer advise.... The manifold etc I could happily do but I dont want to get the wiring wrong. The ancilary loom is simple enough to plug in. If I got a manual loom, is it a matter of plugging into fuse board and using those wires, plugging into the car? I though there was a fair bit of splicing and modifying on the loom and I know I would fudge it up, for sure. No, there's a load of connectors on the OBD2 loom that the C doesn't use/fit and vice versa. Its a case of splice the two together until you have what you need afaik. A couple of peeps on here have done it themselves, have a butchers at this thread. Don't really wanna say too much more as I could be leading you down the wrong road, but am just telling you of my limited knowledge of handing it to someone else to sort out ;) Quote Share this post Link to post Share on other sites
