robrado974
door rubbers advice please
as above .i got a set from here recently,the ones that go all the way round the door opening to form the seal . was wondering were they originaly stuck on or just pushed to fit ? .thanks rob
Push on, but there was a clear adhesive tape strip applied to the seam split all the way round to keep liquid out of the seam. VW part AKL 448 300 04. Any decent half inch tape will do as long as it seals properly. Alternative use a latex type of glue such as carpet glue.
Thats because in may be possible for water to go between the rubber seal and the body and capillary action get to the seam. Main entry is the top of the aperture.
Also make sure the join up of the ends is on the bottom lip above the door sill.
