VR6_ROB 0 Posted January 1, 2011 do i need to open the sunroof to get access to the drains see if its the cause of the rear footwell been soaked my sunroof only tilts cant really see anything any tips on getting the sunroof out?? thanks Quote Share this post Link to post Share on other sites
easypops 8 Posted January 1, 2011 If you take the switch panel off, there should be a allan key type thing on the motor which you can use to manually wind it back........that is if the mechanism is able to do it? Good luck :D Quote Share this post Link to post Share on other sites
