stingman123
Any precautions needed before a big run out?
Hi All,
I'll be driving my C from Middlesbrough to Edinburgh tomorrow, it first really big run out since I' bought it @14 months ago. All servicing is up to date as are tyre's pressure's,fluids etc. Is there any pre drive checks I should check out? i.e bottle of redex etc?
TIA
Nope. If you've checked fluids, tyre pressures etc and had a nose around for any obvious leaks or anything then I'd say you're good to go :)
150 miles? Nothing to worry about, its no more likely to go wrong than on any other drive, as others said, if thats a long run for you then the car will probably thank you for it!
I did 250miles yesterday in mine and the vr is better for it. I always keep a hose repair kit on me just in case lol, I hate leaks.
