Dazmonkey
Help needed. Electrical fault.
Hi all,
My 16v failed it's mot on Friday providing me with a pretty long todo list. About 6 reasons for failing were the electrical faults in the front headlights and indicators. Ie. Both headlights work but o/s all goes out when put on full beam. But in addition, full beam flashed when i indicate right. All n/s works. It's the o/s that the problems are. Mot station says prob bad earth. Can anyone tell me where to find the headlight earth? Anyone had a similar problem?
Thanks
Darran
I've had exactly the same problem 2 days ago re full-beam, my garage said that it's common for leaks under the windscreen to make there way to the fusebox? He replaced it once and it did the trick but 3 weeks later it broke again. I havn't got an uprated loom either though.......
