VR6Pete 0 Posted January 16, 2011 After I did the bulk of the work with chains / head gasket etc.. I had this bit of plastic left over, any ideas what it does and where it goes? Cheers. Pete Quote Share this post Link to post Share on other sites
Fanjita 1 Posted January 16, 2011 I believe that jobber sits against the radiator at the passenger end? Acts a bit like an air guide, sits in the area with the large gap, as the rad is not flush with the bumper and grille. I may be mistaken though, hopefully someone else can confirm this. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 16, 2011 According to ETKA its a 'Air duct cardboard' Quote Share this post Link to post Share on other sites
C488ADO 0 Posted January 16, 2011 Yep defiantly goes against the radiator and bolts to the cross member too iirc very near to the power steering cooling pipe Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted January 16, 2011 Thanks guys. I'll try and pop it back on. Don't suppose any of you have the ETKA diagram? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted January 16, 2011 Here you go fella - Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted January 16, 2011 cheers boss Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 17, 2011 Use those radiator trims if you can fella. They stop schitt being blasted into the engine compartment (snow, rain, grit etc) and also funnel the air in the radiator for more effective cooling. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted January 17, 2011 cheers kev, I will do so.... roll on 5th / 6th feb when the car will actually be able to drive out of my garage at long last :) Quote Share this post Link to post Share on other sites
