emu
Odometer mileage correction. VAG TACHO ?? or WHAT ??
Does anybody correct mileage on your corrado or know what I need to do this. Need to change my clocks and have to correct mileage and want to do this myself no matter what will be the cost. WHat have You used. Is vag tach good for that or maybe something else, but what ??
IIRC you can only increase the mileage (if you want to decrease it that means buying a new instrument cluster with zero miles on it), but that's the only (possibly useless) fact I can bring to this thread .. good luck .. !
you can reduce miles... but don't know how.. I was close in buying a storm in 1998 that had been clocked 50K, it was only after contacting VW to confirm the history of the car it came to light. wish i took note of the reg plate afterwards :(. so threre is one storm in green going about with less miles on the clock
Guy hartley used to have the kit to do this back in the day...
VAGTACHO doesn't work but you just need the right kit to overwrite the eeprom.
Don't You suppose to know what kit is that ??
