fendervg 33 Posted February 4, 2011 Came across these fuse holders from Posi Products - the nice thing is that there is no soldering or crimping - just trim the wire and the exposed part is inserted into one of the end caps and tightened. I've used the blade holder to sort out an alarm fuse problem where the install monkey has used a push on spade that kept coming loose - no alarm, no car. The second one is handy for the headlight earth fuse preventative install - will take a Maplins 200 ma fuse. They are a bit pricey but worth it. They also do a nice vampire tap along the same lines and an inline splicer as well as waterproof ones. Available online from the manufacturer or from Radionics - might be worth a group buy as the price comes down with quantity. Just search for posi tap or posi twist. Quote Share this post Link to post Share on other sites
