Rams
Slam panel / Headlights
There are small clips that sit in the holes which the headlight top screws go into. I think mine were really rusty and have been removed so it could all be rubbed down.
Are these available?
Rams
clip v811 807 577 c x6 36p each
screws vn 013 972 9 x2 21p each
screws vn 013 969 21 x4 16p each
did mian least year
Im not sure if I have the correct part number? I called TPS and gave the number you listed but there are 6 of them. I thought there were only 2 on each side making 4?
The screw that holds the headlight in place at the top goes through a speaker style clip, those I have its the part that the screw goes into the slam panel so the screw has something to latch onto. They are very small and I think metal. must be 3 or 4 mm?
Found the bits I needed, see picture for anyone else needing the scuttle clips, No 14
Edited by Rams
the scuyyle panel is where the window wipers are
the cilps for the headlight to slam panel look like this
Edited by eddy.h
23 is the clip x3
22 is the top screw x2
24 is the bottom screw x1
this is for each headlight
